It is currently Fri May 22, 2026 3:02 pm
 Post subject: You know you're old if
PostPosted: Mon Dec 07, 2009 2:05 pm
you worked on any of these..
http://oak.cats.ohiou.edu/~postr/MRT/
PostPosted: Mon Dec 07, 2009 2:15 pm
Joey,
A tube preceded a transistor which preceded a microprocessor.
http://en.wikipedia.org/wiki/Transistor
http://en.wikipedia.org/wiki/Vacuum_tube
PostPosted: Mon Dec 07, 2009 8:19 pm
Boy, some of those pictures (but NOT ALL) sure bring back memories!
Wiz
PostPosted: Mon Dec 07, 2009 9:03 pm
If you look at the ham shack pic under the arrl flag and just to the right of it is a hq-180 hammarlund. It sorta matches the ones i used to work on in the service.
I used to work on stuff older than that even. Try a rotating phenolic doughnut with 6 turns of wire wrapped on it and glued suspended inside a copper coil of tubing to set the freq in a tube system.
Joe
PostPosted: Mon Dec 07, 2009 9:11 pm
Sean wrote:
Joey,
Huh? U talkin to me?
PostPosted: Mon Dec 07, 2009 9:13 pm
Joe
Not to date myself here, but that almost sounds like an adjustable tickler coil on a regenerative receiver.
PostPosted: Mon Dec 07, 2009 9:15 pm
Sean wrote:
Joey,
Preceded by the spark gap.
http://en.wikipedia.org/wiki/Spark_gap
Users browsing this forum: No registered users and 219 guests
