It is currently Sun May 24, 2026 7:04 am
PostPosted: Thu Sep 10, 2009 5:28 pm
Anyone know anything about these?
According to Amazon.com.....
Product Description
TriSquare has revolutionized 2-way radio communication with eXtreme Radio ServiceTM (eXRSTM). eXtreme Radio Service (eXRS) two-way radios use proprietary Frequency Hopping Spread Spectrum (FHSS) in the ISM band (900 MHz frequencies). This FHSS system combines the power of digital technology with narrow band FM modulation technique. Merging the two technologies facilitates a radio communications system that maintains a narrow band base signal to ensure for maximum usable range within a given dB power budget, comparable to traditional fixed frequency narrow band FM radios, but with the added benefit of wide band digital security and privacy provided by the frequency hopping spread spectrum algorithm. Maintaining the information signal as narrow band FM modulation centered on discrete frequencies allows for a large pool of non-overlapping hopping frequencies to draw upon within a given section of the radio frequency (RF) spectrum. The pseudo-random drawing of the hopping frequencies spreads the total signal power equally over the entire bandwidth of the RF spectrum used, which ensures minimal interference between many simultaneous, independent users. Interference Free is a major advantage that eXRS has over existing FRS and GMRS radios. Based on a contracted study from the Electrical and Computer Engineering Department of a major university, more than 100,000 eXRS users within talk range can enjoy uninterrupted communications. Whereas, FRS/GMRS quickly becomes unusable with just a few tens of users within range of each other. Bottom-line is that the eXRS two-way radios provide private communications in areas where FRS/GMRS conversations can be congested or impossible. Depending on which model you choose, your eXRS radio will have 1,000, 10,000, or all 10 Billion eXRS channels available for your use. Each radio offers Voice-operated transmission (VOX) for hands-free operation with headset compatibility.
Review on Amazon.com.....
The TSX-100 radio is simply one of the best short range 2-way radios available. It uses the 900Mhz ISM band (902-928Mhz range). And is full 1-watt. Uses spread spectrum technology (similar to CDMA Cell Phones: Sprint, Verizon Wireless, US Cellular, Cricket) which makes it JAM-PROOF and highly unlikely that anyone can monitor while using the best scanner radios. 900Mhz band means easy penetration thru thick walls and buildings with dense materials concreate and metal. It is simply the best for Indoor-to-Outdoor or vice-versa comms. And has identical coverage with VHF when used for Outdoor-to-outdoor use.
The TSX-100 does not have all of the exra bells and whistles of the TSX-300 radio:
- 1,000 virtual channels (using FHSS)
- is compatible with all TSX-100 radios
- is compatible with all TSX-300 radios (below channel 1,000 ;
channels 0-999 allows interopability to any Trisquare radio)
(See my review of the TSX-300 for a list of some of the bonus
features on the TSX-300)
With the PRO features, there is one notable CON:
- Do NOT place the TSX-300s or TSX-100s too close to each other.
- They sometimes experience De-Sync issue when a unit nearby
transmits too close. So keep them 4 or more feet apart from
each other. This only occurs when too close to other Trisquare
radios. This does not seem to occur when other nearby radios
or cell phones are placed too close. So no need to worry about
MURS, FRS, GMRS or HAM radios are under 3 feet away.
At least 95-100% of all of the bad reviews or complaints about this radio is over this single flaw in the radio. Rule of thumb, keep the
TSX-300s and TSX-100s a minimum of 4 feet apart from each other at all times, and you will never have any problems at all. Simple right?
Even the TSX-100 is so much better than any MURS, FRS or GMRS radio.
900Mhz just has superior radio properties over all VHF and the rest
of the UHF band. 900Mhz penetrates and bounces around inside buildings
better then any other UHF service. And certainly superior over VHF as VHF does NOT bounce well inside any buildings. Instead VHF gets knocked out of phase, and its wavelength mostly gets cancelled-out or worse yet ABSORBED into the building's materials: concrete, wood & metal. VHF is an OUTSIDE only band. UHF is a good inside and outside band. 900Mhz has the best properties. FRS/GMRS operates at 462 & 467Mhz. Take 462 x 2 and that equals: 924Mhz, which means that 900Mhz has a wavelength that is HALF that of FRS/GMRS. Which means none of the wavelength phase interference of VHF or even of the low-UHF at 462Mhz. Again, it boils down to superior in-building penetration. Thru Concrete, Wood & bouncing off of Metal.
Enjoy your TSX-100, enjoy the superior 900Mhz properties for indoor-to-indoor or indoor-to-outdoor (also vice-versa), or even outdoor-to-outdoor comms. Its FHSS full 1-watt of power will show its superior ability over all MURS, FRS & GMRS radios.
- MURS - VHF 2-watts ERP (Poor Indoor properties - not recommended for
any indoors use at all ; Any scanner can receive, no privacy)
- FRS - UHF 1/2-watt (Good Indoor properties - 1/2 watt max power)
Any scanner can recieve, no privacy ; some HTs have limited voice
scramble function)
- GMRS - UHF 50-watt (Good Indoor properties - 5-watt HTs are hard
to find ; Any scanner can recieve, no privacy ; some HTs have a limited voice scramble function)
- EXRS - 900Mhz 1-watt (Superior Indoor properties - full 1-watt HTs)
FHSS assures no scanner can monitor, wonderful privacy feature)
PostPosted: Thu Sep 10, 2009 7:59 pm
I used one at the Dayton Hamfest in 2008. It seemed to work real well. The audio has the slight hint of digital (with some tinny qualities), but overall they sounded fine. The range was comparable to UHF simplex. We had NO interference or desense issues with them (and that's a real challenging RF environment). Battery life was excellent - went all day without significant battery drain.
I'd recommend them - apparently, some of the engineers are hams, so they took great care at designing them to minimize interference to the current 900mhz amateur allocations.
Brad.
PostPosted: Thu Sep 10, 2009 8:30 pm
Thanks Brad.
I see REI sells them as well as Amazon.com
PostPosted: Thu Sep 10, 2009 9:52 pm
I see ole' sam has got 'em too...
http://www.walmart.com/catalog/product. ... id=8456521
PostPosted: Thu Sep 10, 2009 10:06 pm
I like Walmart's description...
"TriSquare Deluxe eXRS Digital 2-Way Radio with FHSS
Deluxe eXRS digital 2-way radio in realtree advantage timber HD camouflage
Private and secure communication with FHSS and 10 billion channels
Interference free, no harassment from other radio users
Text messaging between units"
Hey man I really like your new radio. Yeah, it has 10 billion channels, looks like a
stick of wood and you can text on it and those scanner guys can't listen to me :bowrofl:
PostPosted: Thu Sep 10, 2009 10:17 pm
"Private and secure communication with FHSS and 10 billion channels"
Breaker, breaker Channel 9,999,999,919 seen any smokies :?: :bowrofl:
PostPosted: Sun Sep 20, 2009 4:46 pm
I've found that the de-sync problem occurs when the units have not communicated with each other after about 15 seconds or so, regardless of range. (We were about 75-100 feet apart when using them.)
The Motorola DTRs are a much better radio, but also cost significantly more.
-Tom, W1WSO -- Plymouth, CT
http://tf.sdf.org/monitor/
