It is currently Wed May 13, 2026 3:11 pm
PostPosted: Tue Apr 28, 2009 11:04 am
Several years ago Radio Shack sold a window clip antenna mount. This device would sit on a window and you would roll up the window to keep it in place. On the outside, you would attach the "rubber duck" antenna from your scanner and on the part inside the window there was a cable that would attach to the antenna mount on your scanner.
I have seen one or two of these recently on ebay. Apparently RS no longer sells them. Has anyone in the group used one of these and if so how effective were they? I am looking for something relatively inexpensive that I can use on my pickup to increase listening range while I am out and about.
Many thanks,
Wayne
Wayne
KF7FYL
PostPosted: Tue Apr 28, 2009 3:17 pm
Many thanks,
Wayne
I've used one in rental cars for years, and also hanging over the curtain rod in hotel rooms. Works fine for me. Not as good as a decent mag mount in the center of the roof or hotel a/c unit, but a decent solution for carry-on luggage travelling. It primarily depends on the duck antenna you use. The stock one with my PSR works great, but an aftermarket multiband duck should work wonders.
PostPosted: Wed Apr 29, 2009 5:08 am
Suggestion: I would do an "image search" with google for "window clip antenna mount" and go from there. You will be able to view the images of many styles and possibly find a source. I used one several years ago and found an increase of signal strength reception in marginal areas.
PostPosted: Thu Apr 30, 2009 9:27 pm
Like this?:
http://cgi.ebay.com/BNC-Over-the-Window-Antenna-Mount-Clip-On-w-6-RG58_W0QQitemZ120081961548QQcmdZViewItemQQptZCB_Radios?hash=item120081961548&_trksid=p3286.m20.l1116
PostPosted: Thu Apr 30, 2009 9:29 pm
Dang it!
Now you went and made me buy something!
Been meaning to pick up a couple o' those.
I'll let you know how I like it when it arrives.
PostPosted: Fri May 01, 2009 8:52 am
Wow I am going to have to pick up the antenna on that ebay site...
"15000 WATT CB ANTENNA CHROME DUAL COILS W 3/8-24 THREAD"
Some serious power for CB :bowrofl:
Who needs a new solar circle with one of those :D
PostPosted: Fri May 01, 2009 9:34 am
The Godfather looks like he's had too much rf. Course he had some Captain Morgan's to insulate him from the damage.
http://www.youtube.com/watch?v=jLXNUMEj ... re=related
"until you figure out what you want to do, You'll know what you want to do"
PostPosted: Tue May 05, 2009 7:46 pm
As promised, reporting back after receiving the BNC window antenna mount purchased off ebay.
Well worth the >$20 shipped to my door. I was surprised at the quality, and for my purposes it works great.
(employer freaks if even a mag mount appears on their rig)
PostPosted: Tue May 05, 2009 10:27 pm
I'm in the same situation when I use the company cars provided to me. I have a little MFJ window clip that works good for the scanner and will TX with a 5W radio.
PostPosted: Sun May 10, 2009 12:51 pm
I've used one on the company car from time to time for several years and it is alot better than having the scanner inside the vehicle. I want to say I got mine thru one of the ham stores (HRO or AES). Here's the MFJ version....which is also available in an SMA mount. Results of course varie with what antenna you use. I've been thinking about getting something like a RH77 and trying that given the reports of how it works on a scanner.
http://www.mfjenterprises.com/Product.p ... id=MFJ-310
