It is currently Wed May 20, 2026 10:07 am
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
PostPosted: Sun Apr 26, 2009 8:24 pm
So, I'm trying to figure out if it's worth spending the extra buckage. I'm getting everything I want to listen to with my Pro-164, which I picked up on sale for $99 back around Christmas. Sometimes it makes very strange noises on my 800Mhz listening (digital noises, possibly attenuation problem) and doesn't do great in some of the valley areas, but I think that's probably antenna as much as the radio (I'm currently using the Radio Shack 800Mhz antenna, haven't bothered upgrading the antenna beyond that yet).
I'm listening to WSP, some DoT, King Cty Sheriff, Several fire agencies (mostly 800Mhz), and some amateur frequencies.
Opinions/advice appreciated.
PostPosted: Sun Apr 26, 2009 8:52 pm
Tough call. The frontends on the latest Unidens and RS/GRE's have overload issues. I've been holding my breath to see if any of these manufacturers clean up their RF frontends when they release their next models.
PostPosted: Mon Apr 27, 2009 12:46 am
I drool over the PSR. By spec, it seems to handle multi site quite well. The new Unidens do too. But the PSR has a really nifty feature that figures out the LCNs for LTR for you. And since it uses scan lists instead of banks or systems, it's pretty easy to scan conventional and trunked at the same time. The Unidens can do this, but you need two different systems.
I have a Uniden BCD396T and two Pro-97s (the non-rebandable version of the Pro-164). They each have their own purpose, and I like the fact that I'm not limited to 10 banks on the 396.
I'd base it on these things: 1) Do you want to monitor the silence of the IWN? It's really the only digital system 'round here. Of course there's the FDC in SeaTac, but it has pretty limited range. 2) Would you benefit from having more than 10 banks? 3) Do you want to learn a new scanner?
I don't know if scanners will ever be selective enough. I know that even a portable radio kicks butt over any scanner. I've picked stuff up on a portable while the scanner was silent on the same frequency.
PostPosted: Mon Apr 27, 2009 7:49 am
I have noticed IWN mentioned more and more often. Can someone please explain what this is.
Many thanks,
Wayne
Wayne
KF7FYL
PostPosted: Mon Apr 27, 2009 7:58 am
Many thanks,
Wayne
VHF Motorola trunk system for federal agencies.
PostPosted: Mon Apr 27, 2009 8:21 am
Rich,
Thank you,
Wayne
Wayne
KF7FYL
PostPosted: Mon Apr 27, 2009 1:49 pm
I've not yet had an overload problem on the PSR, however I went from an older scanner that did straight to the PSR, so I'm adept and looking at the area and tuning the squelch and attenuator to match.
One thing I've recently learned to like about the PSR is the ability to put all sorts of differing stuff in a 'list'. I.e.:
List 1-
Pierce Co Sheriff conventional
Puyallup TRS
Limit search 165-166mhz
Sweeper search 406-420 nearfield stuff
Puyallup schools conventional
etc.
PostPosted: Mon Apr 27, 2009 2:40 pm
My PSR-500 overloads real bad on VHF in Los Angeles. UHF and 800 are tolerable though. Often this can be attributed to handhelds having more sensitive frontends as a way to compensate for their small antenna plus less component count (filters etc) to keep the package small. Usually you can expect mobile radios to have a better designed frontend (PIN-diode switched bandpass filters, inband varactor passband tuning, triple-conversion, etc). Unfortunately this is not the case with the latest batch of scanner radios. In fact the older BC780XLT has a better frontend than the current BCD996T. Not to mention the PSR-600 mobile has the same sloppy frontend as the PSR-500 handheld. Generally the PSR500 is great in suburban/rural areas but it gets trashed in urban areas especially when connected to a mobile antenna. I'd be happy to pay more for the radio if the manufacturers would clean this crap up.
PostPosted: Mon Apr 27, 2009 5:19 pm
I haven't had any problems in Seattle proper, yet. I tried VHF when I was last in LA, but all I listened to was that 2-meter machine we talked about, which came in great. I'll give it a try in July when I'm back down there.
PostPosted: Wed Apr 29, 2009 8:37 pm
I guess I'll keep watching. The RadioShack guy said I could get the 106 for around $400, and I see Hamradio.com has the GRE-500 for $450 or so...
PostPosted: Sat May 02, 2009 8:55 pm
I have the Pro-106 and my I notice the overload only when I connect it up to my Diamond X50 on VHF; if I turn on the attenuator, it goes away.
PostPosted: Sat May 02, 2009 10:32 pm
PSR-500: Built in discriminator data output
PostPosted: Sun May 03, 2009 8:50 am
so do the new uniden HT's just a FYI
PostPosted: Thu May 14, 2009 2:21 pm
i'm ron c,new back to B.C. canada,have the pro 106...........looking for help on freqs in the bellingham area-for pd/fd/border patrol/marine ect
i love this radio
Find "em Hot Leave "em Wet
PostPosted: Tue Jun 02, 2009 2:42 pm
Bringing this up again because I saw this http://www.uniden.com/products/productd ... er=Digital and it looks very appealing. i would love a smaller sized radio than my Pro-164. I also like the idea that it has a remote head for car operation....
Does anyone have one of these yet?
Users browsing this forum: No registered users and 36 guests
