It is currently Thu May 14, 2026 1:55 pm
PostPosted: Fri Mar 20, 2009 1:28 pm
So I might get me one of these that a guy has for sell, but apparently its the 1st NON Chrystal scanner. But you program it by punching holes in a card, for each individual scanner,then sliding the card into the front of the scanner. So are any of you guys familiar with this type of scanner? Because if I get it, then cant program the dang thing I am going to be pretty aggravated. So if i cant I am hoping that someone on here might be able to help me out. THANKS!
!BN5zMtwBmk~$(KGrHgoOKjcEjlLmYj(RBJsBTZpMN!~~_12.JPG [ 25.28 KiB | Viewed 1122 times ]
PostPosted: Fri Mar 20, 2009 1:38 pm
It appears to be a clone of the SBE OptiScan. I put one up on the board in the "Classifieds" in June with no takers. If you need the manual, which contains the programming codes, I can get it to you.
PostPosted: Fri Mar 20, 2009 2:13 pm
So basically you look up a frequency and it tells you a different set of numbers to punch in or whatever? Sounds very strange lol.
Is yours still for sell/ have pics of it?
PostPosted: Fri Mar 20, 2009 3:52 pm
Sorta like an early binary code thing. Sorta.
PostPosted: Fri Mar 20, 2009 4:52 pm
Yep thats what I read about these scanners. I guess they were not around for long, little bit before my time but I never knew these existed. Im going to buy one from Speedracer instead of that one of EBAY, just so I can have one lol
