It is currently Wed May 13, 2026 3:10 pm
 Post subject: Motorola RDX portables
PostPosted: Sat Jan 10, 2009 3:22 pm
Motorola has some new business band hand helds out.
8 channel vhf @ 2watts
8 channel uhf @ 4watts
16 channel uhf @ 4watts
Below are freqs avail for them and also the default channels in them.
They must be programmed with software to change settings from default.
Motorola RDX VHF:
1 151.6250 25.0 kHz
2 151.9550 25.0 kHz
3 152.8850 25.0 kHz
4 152.9150 25.0 kHz
5 151.7000 12.5 kHz
6 151.7600 12.5 kHz
*7 152.9450 12.5/25.0 kHz
*8 151.8350 12.5/25.0 kHz
*9 151.8050 12.5/25.0 kHz
†10 151.5125 12.5 kHz
11 151.6550 25.0 kHz
12 151.6850 25.0 kHz
13 151.7150 25.0 kHz
14 151.7450 25.0 kHz
15 151.7750 25.0 kHz
16 151.8650 25.0 kHz
17 151.8950 25.0 kHz
18 151.9250 25.0 kHz
20 154.4900 25.0 kHz
21 154.5150 25.0 kHz
†22 154.5275 12.5 kHz
23 154.5400 25.0 kHz
24 153.0050 25.0 kHz
25 154.6550 25.0 kHz
26 158.4000 25.0 kHz
27 158.4075 12.5 kHz
RDX VHF 8CH Radios Default Frequencies -
(RDV2080d)
Channel Frequency # Frequency
(MHz) Code # Code Bandwidth
1 20 154.4900 1 67.0 Hz 25.0 kHz
2 21 154.5150 1 67.0 Hz 25.0 kHz
3 1 151.6250 1 67.0 Hz 25.0 kHz
4 2 151.9550 1 67.0 Hz 25.0 kHz
5 10 151.5125 1 67.0 Hz 25.0 kHz
6 12 151.6850 1 67.0 Hz 25.0 kHz
7 15 151.7750 1 67.0 Hz 25.0 kHz
8 26 158.4000 1 67.0 Hz 25.0 kHz
Notes:
• (†) Bandwidth for frequencies 10, 22 and 27 are not selectable and different from XTN. You might
notice the communication quality differences when using these frequencies to interoperate with XTN
radios.
• (*) Due to FCC regulations these frequencies (six in total) are different from the previous Motorola
Legacy Series radios. This means that if you select the RDX radio in one of these frequencies the
radio will not inter-operate with an XTN radio. In order for a RDX radio to inter-operate with an XTN
radio, make sure you choose any of the frequencies (21 in total) that are common for both radios.
Motorola RDX UHF:
1 464.5000 12.5/25.0 kHz 14 461.1625 12.5 kHz
2 464.5500 12.5/25.0 kHz 15 461.1875 12.5 kHz
*3 467.7625 12.5 kHz 16 461.2125 12.5 kHz
*4 467.8125 12.5 kHz 17 461.2375 12.5 kHz
*5 467.8500 12.5/25.0 kHz 18 461.2625 12.5 kHz
*6 467.8750 12.5/25.0 kHz 19 461.2875 12.5 kHz
*7 467.9000 12.5/25.0 kHz 20 461.3125 12.5 kHz
*8 467.9250 12.5/25.0 kHz 21 461.3375 12.5 kHz
9 461.0375 12.5 kHz 22 461.3625 12.5 kHz
10 461.0625 12.5 kHz *23 462.7625 12.5 kHz
11 461.0875 12.5 kHz *24 462.7875 12.5 kHz
12 461.1125 12.5 kHz *25 462.8125 12.5 kHz
13 461.1375 12.5 kHz *26 462.8375 12.5 kHz
*27 462.8625 12.5 kHz 38 466.1375 12.5 kHz
*28 462.8875 12.5 kHz 39 466.1625 12.5 kHz
*29 462.9125 12.5 kHz 40 466.1875 12.5 kHz
30 464.4875 12.5 kHz 41 466.2125 12.5 kHz
31 464.5125 12.5 kHz 42 466.2375 12.5 kHz
32 464.5375 12.5 kHz 43 466.2625 12.5 kHz
33 464.5625 12.5 kHz 44 466.2875 12.5 kHz
34 466.0375 12.5 kHz 45 466.3125 12.5 kHz
35 466.0625 12.5 kHz 46 466.3375 12.5 kHz
36 466.0875 12.5 kHz 47 466.3625 12.5 kHz
37 466.1125 12.5 kHz *48 467.7875 12.5 kHz
*49 467.8375 12.5 kHz 61 467.1875 12.5 kHz
*50 467.8625 12.5 kHz 62 467.4625 12.5 kHz
*51 467.8875 12.5 kHz 63 467.4875 12.5 kHz
*52 467.9125 12.5 kHz 64 467.5125 12.5 kHz
53 469.4875 12.5 kHz 65 451.1875 12.5 kHz
54 469.5125 12.5 kHz 66 451.2375 12.5 kHz
55 469.5375 12.5 kHz 67 451.2875 12.5 kHz
56 469.5625 12.5 kHz 68 451.3375 12.5 kHz
57 462.1875 12.5 kHz 69 451.4375 12.5 kHz
58 462.4625 12.5 kHz 70 451.5375 12.5 kHz
59 462.4875 12.5 kHz 71 451.6375 12.5 kHz
60 462.5125 12.5 kHz 72 452.3125 12.5 kHz
73 452.5375 12.5 kHz 82 456.4375 12.5 kHz
74 452.4125 12.5 kHz 83 456.5375 12.5 kHz
75 452.5125 12.5 kHz 84 456.6375 12.5 kHz
76 452.7625 12.5 kHz 85 457.3125 12.5 kHz
77 452.8625 12.5 kHz 86 457.4125 12.5 kHz
78 456.1875 12.5 kHz 87 457.5125 12.5 kHz
79 456.2375 12.5 kHz 88 457.7625 12.5 kHz
80 456.2875 12.5 kHz 89 457.8625 12.5 kHz
81 456.3375 12.5 kHz - - -
RDX UHF 8 CH Radios Default Frequencies -
(RDU2080d)
1 2 464.5500 1 67.0 Hz 25.0 kHz
2 8 467.9250 1 67.0 Hz 25.0 kHz
3 5 467.8500 1 67.0 Hz 25.0 kHz
4 6 467.8750 1 67.0 Hz 25.0 kHz
5 10 461.0625 1 67.0 Hz 12.5 kHz
6 12 461.1125 1 67.0 Hz 12.5 kHz
7 14 461.1625 1 67.0 Hz 12.5 kHz
8 16 461.2125 1 67.0 Hz 12.5 kHz
RDX UHF 16 CH Radios Default Frequencies -
(RDU4160d)
1 1 464.5000 1 67.0 Hz 25.0 kHz
2 1 464.5000 4 77.0 Hz 25.0 kHz
3 1 464.5000 8 88.5 Hz 25.0 kHz
4 1 464.5000 29 179.9 Hz 25.0 kHz
5 1 464.5000 0 - 25.0 kHz
6 2 464.5500 1 67.0 Hz 25.0 kHz
7 2 464.5500 6 82.5 Hz 25.0 kHz
8 2 464.5500 10 94.8 Hz 25.0 kHz
9 2 464.5500 29 179.9 Hz 25.0 kHz
10 2 464.5500 0 - 25.0 kHz
11 22 461.3625 3 74.4 Hz 25.0 kHz
12 30 462.4875 5 79.7 Hz 25.0 kHz
13 32 462.5375 7 85.4 Hz 25.0 kHz
14 34 462.0375 9 91.5 Hz 25.0 kHz
15 36 464.0875 11 97.4 Hz 25.0 kHz
16 38 464.1375 13 103.5 Hz 25.0 kHz
Notes:
• (*) Frequency limited to 2W maximum power output
• When referring to XTN radios, note that frequencies from # 57 to # 89 are 33 new additional frequencies
PostPosted: Sat Jan 10, 2009 7:02 pm
I believe you can get the programming software for free if you register. Of course you'll have to take out a second mortgage for the programming cable, but free software is good.
PostPosted: Sat Jan 10, 2009 10:33 pm
Motorola giving free software?
Ill believe it when pigs fly! :shock:
PostPosted: Sat Jan 10, 2009 10:54 pm
Go to motorola.com/RDX, click "Skip intro" then "Resouces" then "Customer Programming Software". It's a 7.2 MB zip file that won't download unless you disable your popup blocker. Soooo many poor design choices on that site. And here's the USB cable via Amazon, $50. Looks like a standard USB cable.
PostPosted: Sat Jan 10, 2009 11:02 pm
Damn it! Flying bastard just took off my chimney!
I guess I should believe it. They have provided free cell phone software so this shouldnt surprise me.
:mrgreen:
PostPosted: Sun Jan 11, 2009 9:01 am
And I'm sure that the APX software will be free too......
