It is currently Fri May 15, 2026 11:01 pm
PostPosted: Thu Oct 30, 2008 6:47 pm
I have always wondered, when the SWAT team is out front and they say they are going to my #2 or #3 side, how do they figure which side is which?
I assume #1 is the front, and logically #3 would be the back on a simple, square(ish) building, but how do they figure the actual side #'s?
Also, I heard reference to the #1 -1 -1 window.
I am guessing #1 side, 1st floor, 1st window, but would that be from the left? or right?
TNX
PostPosted: Thu Oct 30, 2008 8:29 pm
also a,b,c,d
Left to right, 1 is front enterence 2 is right 3 is back or next right ...etc
window is the same right to left (AFAIK)
edit : I dyslexia the L and R and accidentally put R to L
1 Left 4 Right 4 corner house would be
1 front door
2 right side from looking at the front door
3 rear from front door
also A would be front and C rear
PostPosted: Fri Oct 31, 2008 11:11 am
Before team goes on a raid, they get together and talk about the raid and that is when they are told what side is which and what window is what. I have always assumed looking at the front of the house, side 1 front, right side would be side two the back 3 and the left 4, if the house is square that is. So just counter clockwise pretty much. All just speculation though since I am not a SWAT member. But if they thought they might be being listened in on by whomever they are raiding they might change it up a little bit.
PostPosted: Fri Oct 31, 2008 1:03 pm
i can confirm that is standard LEO/military practice. they wouldn't typically change it up - as you wouldn't change any procedure that needs to be second nature, however if communication is required they will just use nexthell or encrypted depending on how they are operating, they wouldn't typically obfuscate the procedure but the names of things. aka code names for places or people
PostPosted: Fri Oct 31, 2008 2:00 pm
For fire suppression, there are in general two rules used..
1. Side facing the road is side A. (normally the front of the structure)
2. Side where the command post is setup is side A.
In general the first in engine will normally stop at the front of the structure which will be the road side and also where command is setup.
But ultimately it's commands call on what side A is.
PostPosted: Fri Oct 31, 2008 2:24 pm
what if your in Australia where things run the other way?
PostPosted: Fri Oct 31, 2008 10:31 pm
In fire suppression, after side A is established, do they go clockwise or counter-clockwise to establish B-C-D, etc.?
Gampawayne
Wayne
KF7FYL
PostPosted: Fri Oct 31, 2008 11:23 pm
correct
PostPosted: Sat Nov 01, 2008 7:49 am
Are you sure "Fire suppression" doesn't refer to Fire Fighting ? In Law Enforcement terms -- fire suppression is "Duck & Cover".
PostPosted: Sat Nov 01, 2008 8:25 am
in that case its CIA, ABCD are put on hold for WTF and KSA, or SNAFU depending on the department.
PostPosted: Sat Nov 01, 2008 12:26 pm
Spud-man -- We are just to far ahead of the crowd.
