It is currently Sat May 16, 2026 3:37 pm
PostPosted: Fri Sep 12, 2008 10:27 pm
Received via WW-MST mail list
(For info on WW-MST see: http://www.ww7mst.org/ )
After coordination with WX4NHC Coordinators Julio Ripoll-WD4R and John McHugh-K4AG, the VoIP Hurricane Net will be activating at 12 PM ET/11 AM CDT Friday for impact of large Hurricane Ike along the Texas and Louisiana Gulf Coast. The weekly net for this Saturday Evening has been cancelled. WX4NHC, the Amateur Radio Station at the National Hurricane Center in Miami Florida, is expected to activate at 12 PM ET/11 AM CT. They are planning to be active through the overnight hours and well into Saturday and we expect this to be the same for our net.
Given the large size of Hurricane Ike, the concern is there for a widespread swath of significant damage as well as an unusually large area of storm surge flooding from Ike. Damage could also extend well inland. This could be a major strike to the Texas and Louisiana coast and particularly the Houston and Galveston Texas area. We ask any and all stations in or near the affected area and stations that have relays into the affected area to report into our net with weather and damage reports for use by WX4NHC and many other regional and national entities.
For the latest advisory information including watches and warnings, you can go to the VoIPWXNet web site and click Atlantic Tropical Products and click on the advisory information for Ike under the Atlantic Tropical Products section. You can also gather the advisory information from the National Hurricane Center web site at the following link:
http://www.nhc.noaa.gov
The reporting criteria and activation policy for our net during hurricane net activations can be found on our web site at http://www.voipwx.net (Note issue with web site as stated in the first paragraph. Please utilize the typical SKYWARN Reporting Criteria)
Listen Only IRLP/EchoLink capability include the following systems:
IRLP:
Reflector 9508 Sydney Australia Reflector channel 8.
Reflector 9129 New England Reflector channel 9.
EchoLink:
*KC4QLP-C* Node: 290251
*VKEMCOMM* Node: 270177
*N5API* Node: 77433
*IRESC* Node: 278173
*N1TAI* Node: 269929
A streaming audio feed has been setup thanks to the assistance of David McAnally-WD5M. This is the first time he has setup a streaming audio server so please bear with any technical difficulties. The links are listed below:
WD5M Streaming Audio Feed Main page
http://live.wx5fwd.net/
WD5M Direct link to Streaming Audio using OGG Format
http://live.wx5fwd.net/voipwx.ogg.m3u
WD5M Direct Link to Streaming Audio using MP3 Format
http://live.wx5fwd.net/voipwx.mp3.m3u
Bob Carter-KC4QLP has also setup an online stream for up to 32 listeners at the following link:
KC4QLP Streaming Audio Feed
http://kc4qlp.dyn.dns.org:8082/
(I couldn't get this one to work - de N7QOR)
An EQSO listen-only feed is also available via KC4QLP-R.
Lu Vencl-KA4EPS has also set up streaming audio capability. See links below:
KA4EPS Streaming Audio Feed
http://colostreaming.com:8010/listen.pls
http://colostreaming.com:8088/listen.pls
Links to the WD5M streaming audio feeds have also been provided in the Main Menu of the VoIPWXNet web site.
Below is the typical information WX4NHC issues prior to activation of the WX4NHC Ham Station as provided by WX4NHC Coordinators, Julio Ripoll-WD4R and John McHugh-K4AG:
We request all land based stations as well as ships at sea in the areas affected to send us weather data (measured or estimated) and damage reports.
If you are in the affected area and normally monitor on a local Net on VHF, 40 or 80 meters, we would appreciate your checking into the HWN NET or EchoLink/IRLP Net once per Hour to receive the latest Hurricane Advisories and to report your local conditions.
Please do not venture outside during the hurricane to gather weather data.
Your safety is the first priority.
There are many constantly changing atmospheric variables that affect the storm's track and strength.
Please refer to the National Hurricane Center Advisories for official information. http://www.nhc.noaa.gov
WX4NHC will be monitoring the Hurricane Watch Net http://www.hwn.org on 14.325 MHz.
Secondary HF frequencies will be 7.268 MHz and 3.950 MHz +/- QRM, should we loose propagation on 20 meters.
EchoLink "WX-Talk" Conference Room and IRLP node 9219 will also be monitored. http://www.voipwx.net
WX4NHC will also monitor CWOP, APRS and MADIS/MESONET Automated weather stations in the affected area.
Surface Reports using our On-line Hurricane Report form will be monitored.
Amateur Weather Enthusiasts and ON-NHC Volunteers may report directly to WX4NHC on-line.
http://www.wx4nhc.org/WX-form1.html
ON-NHC Volunteers are both Ham Radio Operators and Non-Ham weather observers that use their own weather instruments to submit "Surface Reports" directly to NHC over the Internet via the WX4NHC on-line report form. These "Surface Reports" are very important as they give Hurricane Specialists at NHC a better idea of what is actually happening on the ground level during the storm.
The WX4NHC Group continues to expand its efforts to increase the quantity and quality of surface reports to include many different modes of reception and groups of people; including HF, VHF/UHF IRLP & EchoLink, VHF & HF APRS, CWOP NOAA Program and ON-NHC Weather Observers Network.
(see our web site for more information on these programs): http://www.wx4nhc.org
WX4NHC is very proud to have maintained an active Amateur Radio Station at the National Hurricane Center for the past 28 years.
We appreciate all of the volunteers who help with our efforts.
OUR MISSION: TO HELP SAVE LIVES.
John Mc Hugh, K4AG
Coordinator for Amateur Radio
National Hurricane Center, WX4NHC
Home page:- http://www.wx4nhc.org
Thanks to all for their continued support for the VoIP Hurricane Net!
73,Rob-KD1CY.
Director of Operations for the VoIP Hurricane Net
