It is currently Thu May 14, 2026 8:33 pm
PostPosted: Mon Apr 28, 2008 8:27 pm
would like some suggestions if possible on what this might be. My BC780 seems to be deaf on all trunked freqs. I have 4 Trunked systems on my 780. All it does is scream thru the feqs and never locks onto a control channel. All the conventional stuff works fine. I have had it hooked up to 2 diff. antennas to test this. One being a radio shack mag mount inside my place here the other being a ground plane outside on my deck. With the conventional freqs I'm pulling stuff well over 60+ miles away easily.The trunking freqs are right within a few miles from my location. My Pro-97's have no issue scanning them at all, using a RS 800mhz duckie. I have programmed and re-programmed the freqs. I can't figure this out for the life of me. All the obvious stuff i have checked on the scanner, so i ask for help from you out ther now please. Could it be something in the trunking capabilities is broken? God I hope not. Just seems odd that 4 different trunked systems will not come in at all.
PostPosted: Tue Apr 29, 2008 6:33 am
You've probably tried most of these:
1) Program the same freq as 'conventional' and see if it sounds good.
2) Make sure you push "TRUNK".
3) Trunking type = Motorola etc?
4) Control channel only - even if the 'plan' is wrong, it should at least sit on the control channel.
5) Cycle power.
6) Hard reset (2+9+MAN).
7) Delete the bank completely or program a different bank. (Using s/w or keypad to program?)
8) Monkey with the squelch.
There are a few failures that could kill trunking and not conventional, but I've never heard of one actually happening to anyone.
Flash
PostPosted: Mon May 19, 2008 2:26 pm
Could the CC be locked out somehow? If that doesn't work, I'd do a hard reset.
