It is currently Tue May 26, 2026 12:52 am
 Post subject: Carry Case Pro 97
PostPosted: Sat Jan 06, 2007 2:30 pm
can someone Point me to an online site that Sells Cases for Pro 97s, I Remember Seeing one, but I can't Remember the Website Address,
Thanks 8)
Brian Sewell
PostPosted: Sat Jan 06, 2007 3:12 pm
Try http://www.scannermaster.com as they have 2 styles for the Pro-97. They cost $32.95 and $34.95.
You can find them under "Accessories" click on Leather Cases. Hope this helps you out.
PostPosted: Sat Jan 06, 2007 3:14 pm
Brian,
Check out http://www.scannermaster.com under accessories I think I saw some cases for radio shack portables on there,I think they are about $32.00 on up. another thing You could do is pick up a radio case from galls, they should work for what you want , I get most of my Med supply's and duty gear from them.
PostPosted: Sat Jan 06, 2007 3:40 pm
:D Thanks I'll Check em out 8)
Brian Sewell
PostPosted: Sat Jan 06, 2007 5:34 pm
I purchased a case for my PRO-97 from the link below
and like it very much. It is lite weight and has clear windows
for both the display and keypad. You can use the belt clip
that comes with the radio with this case on.
http://www.lilkase.com/
