It is currently Mon May 25, 2026 7:38 pm
 Post subject: BC245XLT -- Any clues
PostPosted: Wed Dec 13, 2006 10:20 pm
I have a BC245xlt that has just stopped on me. I haven't had time to get to a shop or talk to anyone yet. I thought I would describe the problem and hopefully I might get some clues as to what it could be.
The BATT light started flashing and I hooked it up to the wall charger. When I disconnected it and turned it on the BC245 flashes on the screen once or twice and disappears. The screen remains blank and a low static type noise is heard. The noise gains volume if the volume control is turned up.
I am hoping it is just a battery, but if so why do I get the noise. Any clues would be appreciated.
If it is more than a battery, and can be fixed locally would the closest place be ABC. It's the only one I know of. Would that be the source for a battery as well?
Thank you,
Gampawayne
 Post subject: Battery
PostPosted: Thu Dec 14, 2006 3:42 am
I own a 245xlt and had the same problem. Once I changed the battery it was fixed.
PostPosted: Fri Dec 15, 2006 1:48 pm
Thank you, that worked.
Gampawayne
Users browsing this forum: Google [Bot] and 10 guests
